Switch Phases - Balanced Load - BUG
ricaun
Advisor Advisor
ricaun
A friend found this strange behavior on the Schedule Panel when using Switch Phases on Revit 2021 and 2022.
When you switch phases on an electrical circuit with 2 hot wires and the circuit has a balanced load, for some reason,
Revit unbalance the load circuit and consequently add a Neutral wire even if the Wire Type has Neutral Required disabled.
This just happens on the phases AC and BC, if the circuit is on the phases AB works like should be.
I hope this helps to improve the next version of Revit.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
RobDraw
This is a user help forum. It won't help with improving the next version here. Try the IDEAS forum or product feedback.
Rob
ricaun
I believe nobody search for the answer on the Idea board.
See yaa
