Revit MEP Forum
Welcome to Autodeskโ€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Surface Lines
6 REPLIES 6
stevenson953
1688 Views, 6 Replies
Surface Lines
Hi Guys,
Just got a REVIT model from an architect and I think it wasn't built in REVIT and was converted from an IFC file which came from Solid Works or something similar.
See screencast below.
https://knowledge.autodesk.com/community/screencast/26a0caf3-fe27-41b7-8c81-416d0ac5a37b
I just want to get rid of all the lines across the surfaces.
Hope it's simple ๐Ÿ™‚
Thanks for any help.
Paul
6 REPLIES 6
stever66
in reply to: stevenson953
its hard to know what those lines are (model lines, or part of some solid?).
I would try to save a copy of the revit file, and since it looks like that item is a generic family model, you should be able to select edit family.  If they are simply model lines inside the family, you should be able to select everything, and use the filter to get just the lines, and then delete them from the family.
stevenson953
in reply to: stever66
Thanks for helping!
I did another little screencast below to further explain what I am seeing.
https://knowledge.autodesk.com/community/screencast/a472a076-be3e-4b23-ab97-6aa14a54ce75
Paul
yurikim
Thank you for your posting @stevenson953. Your video is in private, and can't be viewed by others.
How was IFC brought into Revit? Was it imported or linked?
Do you see this triangulated surfaces on other IFC viewer as well? How about having them as ACIS solids?
Yuri Kim
Product Support Specialist, AEC
stevenson953
in reply to: yurikim
Hi Yurikim,
Thanks for responding.
I have made the video public so hopefully you will now be able to view it.
It's actually a linked REVIT model that has been converted from an IFC model produced by a manufacturer.  This is all done before it is issued to the team and me and I have no control over that.
Paul
yurikim
Thank you @stevenson953. If you can't export this again, you could probably explode and simplify the geometry by removing unnecessary lines.
If you can ask to export again, try to export it as  IFC4 and deactivate this option "Keep Tessellated Geometry as Triangulation".
When adding the IFC to the model, make sure that link the IFC to the model. Bind the link if needed.
Hope this helps.
Yuri Kim
stevenson953
Thankyou and I'll pass this onto the originators to see what they can do.
