Space Schedule with Embedded Light Fixtures (Grouped by "Space Type")
trey.ruiz
trey.ruiz
I have read a few posts talking about creating space schedules, even some for embedding light fixtures, but what I can't find, and unable to do in Revit 2019 is group the spaces by "Space Type" and still see the embedded "Light Fixture" schedules.  Any time I try to uncheck "Itemize every instance" I loose the embedded schedules.  But I need the fixture counts by an unitemized "space type".  This is particularly to fulfill the COMcheck "Area Category (Space-by-Space) Method".  I have many spaces that are the same type, but I do not need the fixtures of the same space type broken down, I need the summary of all fixture types, by space type.
Is there no way to see all of the fixtures as grouped by space type?  See attached screen shows of ungrouped, and grouped.
I have also made a light fixture schedule with spaces in it, but there is no information in the space parameters...
fabiosato
When you create a Lighting Fixture schedule, in the Fields tab, in Select available fields from, you can select Space, then you can select space parameters to include in your schedule.
Fábio Sato
hmunsell
if @fabiosato solution didn't solve the problem, can you post the file?
Howard Munsell
fabiosato
Please check the attached file, if I understood your need.
Fábio Sato
benMFTC9
Observer
Observer
I was looking for an answer to the above and this is what I wanted.
The main space schedule should be itemized so you have a list of individual spaces.  The embedded schedule should NOT be itemized so that you have lights grouped and quantified by types.
