Space Naming Utility 2014 Problem
Hi all,
I am using Revit 2014. In my MEP model, I have linked to the revit arch model and set room bounding. I have created my spaces automatically and used Space Naming Utility to get room name from Arch. However, it only creates space but not show room name and in Space Properties it shows "Unoccupied".
My cut plane is not zero, my Visibility is set properly and I already set my model Phase Mapping same Arch model.
I've looked through our forum but there are no solution.
Please help me on it.
abulla
We've found recently that architects have a tendency to add finish floors later in the project, and they'll forget to set them to non Room Bounding. This will mess up our spaces and cause them to read unoccupied. Try opening up the architectural model, isolating the floor category, and check if there are finish floors that are set to room bounding. I'd call the architect too and make them aware of the issue if that's the case.
Thank you kindly, that was begining to drive me mental!!!
