Hello. I'm updating our take-off schedule for duct weight calculation but have run into a series of snags (I think they are all related).
In our schedule, we list out both round and rectangular ducts. But since rectangular and round ducts don't use the same sizing parameters, I have added all of them in for visibility. So we have Width, Height, and Diameter.
From there I apply a gauge size to them with a calculated value. This is handled by two different formulas currently, because I was not able to get anything to combine and work properly for both WxH & Diameter in the same formula. I tried, but it would either process the rectangular or the round ducts, NOT both (just depended on which was first in the IF statements). So here I am with two different calculated columns, one for each.
The formulas for the gauge sizes are (we only go down to 24 and up to 18, nothing should be 26 or 16 GA):
Gauge Size Rectangular =
if(or(Width > 85", Height > 85"), 18, if(and(or(Width > 54", Height > 54"), or(Width < 85", Height < 85")), 20, if(and(or(Width > 30", Height > 30"), or(Width < 54", Height < 54")), 22, if(and(or(Width > 0", Height > 0"), or(Width < 30", Height < 30")), 24,0))))
Gauge Size Round =
if(Diameter > 84", 18, if(and(Diameter > 54" , Diameter < 85"), 20, if(and(Diameter > 30" , Diameter < 55"), 22, if(and(Diameter > 0" , Diameter < 31"), 24, 0))))
Now we get to the pounds per square inch, where things fall apart (at this point). I'd like to combine both the round and rectangular here and apply the proper weight value based on the gauge of the ducts. I'm basing this off of the SMACNA rules (basically the same as this chart for galvanized). Formula is:
Pounds per sq ft =
if(Gauge Size Rectangular = 24, 1.156 psf, if(Gauge Size Round = 24, 1.156 psf, if(Gauge Size Rectangular = 22, 1.406 psf, if(Gauge Size Round = 22, 1.406 psf, if(Gauge Size Rectangular = 20, 1.656 psf, if(Gauge Size Round = 20, 1.656 psf, if(Gauge Size Rectangular = 18, 2.156 psf, if(Gauge Size Round = 18, 2.156 psf, 0 psf))))))))
NOTE, I have tried this formula MANY different ways, here are a couple...
I've reversed the order of sizes:
Pounds per sq ft =
if(Gauge Size Round = 18, 2.156 psf, if(Gauge Size Rectangular = 18, 2.156 psf, if(Gauge Size Round = 20, 1.656 psf, if(Gauge Size Rectangular = 20, 1.656 psf, if(Gauge Size Round = 22, 1.406 psf, if(Gauge Size Rectangular = 22, 1.406 psf, if(Gauge Size Round = 24, 1.156 psf, if(Gauge Size Rectangular = 24, 1.156 psf, 0))))))))
I've setup OR statements for both round and rectangular at the same time (and reversed the orders as well):
Pounds per sq ft =
if(or(Gauge Size Rectangular = 24, Gauge Size Round = 24), 1.156 psf, if(or(Gauge Size Rectangular = 22, Gauge Size Round = 22), 1.406 psf, if(or(Gauge Size Rectangular = 20, Gauge Size Round = 20), 1.656 psf, if(or(Gauge Size Rectangular = 18, Gauge Size Round = 18), 2.156 psf, 100 psf))))
But nothing seems to want to work. All that happens is that whatever is first in the pounds per sq ft formula that is what happens and then the rest just result in a null value. Not a 0, just nothing. So I can either get a 1.156 psf applied, or the other end of the spectrum with a 2.156. And it only applies to the proper GA ducts, then it stops.
I believe this has everything to do with the two different shapes and trying to pull those together in the end, but I have no real way of knowing. The odd thing is is that the PSF formula isn't using those dimensions at all, it's using the Gauge Size results, which are both Numbers (I've tried integers too, doesn't matter). I mean going all the way back, the gauge sizes are using the duct dimensions, so it could be the problem.
Should I just give up and make two different schedules? One for round and one for rectangular. Or is there something I'm missing? Anyone else run into this, thoughts/questions?
