Showing a Fiber Optic Path with a Schedule for Horizontal Lengths
morgan.dentonJJXCT
Message 1 of 11
morgan.dentonJJXCT
Greetings Autodesk Community,
I have a Client that is requesting that we show the paths of some Fiber Optic Cables on our floorplans, and they want a Schedule with the Horizontal Lengths specified for each Path.
I am fairly new to Revit, and was wondering what the best way to show this would be?
They will only need the lines (paths) shown as a representation, and don't need Conduit called out or anything.
Also they would like the Fiber Lines to be a specific Dash-Dot-Dot-Dot style of line type.
I'm sure you might have questions before you can answer, but I'm not sure what else you might need.
Let me know your thoughts,
Morgan.
Replies (10)
Message 2 of 11
iainsavage
I think @hmunsell probably has a method for this, using some other linear component to represent the cable route.
Pipe, conduit, or railing?
You can create a custom line style but there are limitations on the length of the "dots" - something like 0.5mm long if I recall. Look under Manage>Additional Settings>Line Patterns to create the pattern, then apply that pattern to a line style under Manage>Additional Settings>Line Styles
Message 3 of 11
iainsavage
Actually you can create dots, its the length of dashes and gaps which have minimum limitations. Been a while since I have had to create a new pattern.
Message 4 of 11
iainsavage
Message 5 of 11
morgan.dentonJJXCT
@iainsavage thank you for the replies.
I know that the client wants the linetype with a specific style, but first I will need something that I can add to the drawing that will allow me to change the linetype and pull the lengths into a Schedule.
I already have the appropriate Linetype in my drawing (was using it to show the Fiber Paths as a Detail Line), but I cannot pull that info into a Schedule.
Message 6 of 11
hmunsell
LOL... sorry been busy helping setup a new Civil 3D client standard we received in my office 😁.
for measuring total lengths of stuff like that, i usually like using a modified handrail. its one of the few object that will provide a total length and can be tagged that way. The issue with a handrail in your case though it the line style requirement. it can be done, i have done it for our Egress lines with dashes and arrows, but it would be a pain.
since your doing fiber optic anyway, have you considered making a circuit? give it a starting device and and end connection. Circuits will provide an "estimated" distance. In theory, you can then use Edit Circuit Path tool to provide a more desired path and more accurate distance.  Use the Wire tool to display the connection between the devices. i think you can assign the "Wire" a line type and weight in the Object Styles or thru a Filter.  I have not tested that process yet, I'm busy loading 2024 on my laptop and its taking for ever LOL. but its something you can try 😊.
Howard Munsell
Message 7 of 11
iainsavage
As I said, mimic the cable path using another linear object which you can name accordingly e.g. you could copy a generic pipe type and name it Fibre, or do the same for conduit or cable tray or similar.
In part 16 of this post @hmunsell suggests using railing.
Message 8 of 11
iainsavage
You posted just as I was pressing the send button!
Message 9 of 11
hmunsell
That happens to me all the time. I like to test things before I reply and in taking the time to verify something I end up posting seconds after someone else 😂 .
Howard Munsell
Message 10 of 11
morgan.dentonJJXCT
@hmunsell thank you for the suggestion on using a Circuit to run the Fiber.
I am new the the Electrical side of Revit and do not know how to create a Circuit.
I found TONS of videos online and on Autodesk's horrible help pages explaining how to Edit a Circuit, but nothing on creating one.
Would we need to insert specific items at each end of the Circuit to create it?
Do you know of a good video or page that outlines how to do this?
Thank you,
Morgan.
Message 11 of 11
hmunsell
here is a quick video i threw together. I'm using Receptions and a panel, but you can use a Data connector and Ethernet switch tool or any number of other devices. once the circuit is made you should be able to label the circuit, may need a custom tag, to show the circuit length. it should also be able to show in a schedule if needed.
Howard Munsell
