should Linked models from other offices be central, local, or detached
revitworkbench
revitworkbench
We are discovering network lag, and I discovered that we have 5 local versions of central models linked into our model. The local models are on our server, but they are not detached. The Central model for these local models does not exist in our network. So my question is this? If I open all of them, detach them, and discard the worksets and resave it. Will that produce any noticeable results to our model performance? Or should I do something else?
RobDraw
That should help a lot, but not guaranteed.
Rob
I would detach them though I am not sure if it helps.  But I would NOT discard worksets, you want to be able to close irrelevant links' worksets which actually improves performance.
MostafaElashmawy
Discarding the worksets is not recommended if you don't know what filters,viewing options are related to them.
What I propose is :
Detach 1 of them (The most recent one) with preserving the worksets, then save it as central model and use it to generate new locals.
Mostafa Elashmawy
