I am trying to print from Revit 2022 to Bluebeam PDF and I am getting a shif in shaded regions on my Panel Schedules and also other thinks like arrow head fill and text backgrounds are shifting as well.
I am not sure if it is a Revit, Bluebeam or computer issue.
Has anyone seen this behavior, and what's the fix?
Solved by tkbridge. Go to Solution.
i have also noticed something similar in printing from Revit 2022 and Revit 2023. other users do not have the same issue when printing the same sheets. it is only certain machines. All drivers have been updated and machine has been restarted. i also tried printing to raster with the same results.
I agree with @ToanDN and @curtisridenour.
There are several posts in which Bluebeam users report unusual effects when printing and it is almost certainly a Bluebeam issue.
I've never had any such problems when using Prosheets by DiRoots.
The solution for my team was to uninstall and reinstall bluebeam. We are on Revu build 20.3.20
Hopefully that helps.
I found the same solution.
I uninstalled and reinstalled Bluebeam and the problem looks like it was corrected.
Thanks everyone.
