Setting U values for curtain walls?
How can I set the U value for a curtain wall made of glass?  I tried to go to Edit Type, but the option to edit the structure is disabled, how does one specify the material for a curtain wall?  Thanks for the help...
Alaaeldin_Alsahli
This is hard coded information so you can't change the U value on a curtain wall
 you have two options
Option1 create 2 design options
the first one where you have your curtain wall on it
and second design option you will take any wall duplicate it, name is as  (Curtain wall analytical), then create the material and the thickness that you want ( it wont look like a curtain wall but at least you could calculate the U value with it
or
Option 2 is you go to (Analyze) Tab then (heating and cooling load)--- detail tab-- select a space then click on construction type and select the wall you want for exterior wall
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for the response.
The problem with Option 2 is that not the entire wall is a curtain wall with glass.  The rooms are shops, with parts of the wall made of glass.
Is option 1 really my only hope?
Alaaeldin_Alsahli
Well then forget about you curtain wall and use Custom windows where you could play with U value
Alaaeldin Alsahli
For anyone who is wondering, I just spoke with Autodesk Support in Munich who suggested to click on the system panel element within the curtain wall via the Tab key and from there I can specify the material and the U value.
Alaaeldin_Alsahli
this is good to know never thought of it but how are you going to calculate the energy
because there is a problem with the curtain wall when comes to energy analysis
it doesnt have the same surface area when exported to other software, where a simple window has a better data to be calculated
read section
5.6 Windows/Curtain Wall/Spandrel
5.6.3 Curtain Wall
http://sustainabilityworkshop.autodesk.com/sites/default/files/core-page-files/leveragingbimforenerg...
please keep me updated
Alaaeldin Alsahli
baselelhusseini
Community Visitor
Community Visitor
Thank you!
