Set the Default Viewport Type
sragan
sragan
I would like to change the default viewport type or view title.   For example, when a view is placed on a sheet, the viewport type shows the viewport name, number, and sometimes the scale.  Like this:
The viewports always default to the "Title w Line".   After searching online, it appears the default view title should be set by using the "Loaded Tags and Symbols" setting for "Views".  However, I have that set to our preferred view title, but it doesn't work.  When I drag a view onto a sheet, it still defaults to "View w Title".
And I can't seem to purge "View w Title" either.  Nor can I find it in the project browser.
Any ideas?
tawilson
I tried to change the default viewport type for years then I found someone posted the work around on here. Duplicate the default viewport type then change the default type to show what you want.
apjones
I set this in our template years ago and it did the trick.  Does this no work for you?
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
sragan
Nope, still title w line.
Even with deleting all the viewports, purging everything possible, and trying the Loaded Tags again.
sragan
No, doesn't seem to work.  Now that I look closer at that setting, "Title w Line" isn't even an option.  The only options there are the "title" settings for a viewport type.
The viewport family types aren't even an option for that setting?
I guess the obvious solution is to just rename "Title w Line", and make its settings the ones I want to default to.   Maybe that's what the first post meant to do.
apjones
Honesty, I d not think that that is what I did, but if it works, go for it.  I set this in our template over a decade ago, so I'm a little fuzzy on exactly what I did.
Pete
HVAC-Novice
For me setting the default doesn't work and Revit chooses what it wants. And I then have to manually swap the type in properties.
The whole viewport type thing is messed up and you can't remove unneeded ones. Has been messed up for decades IME.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
