Serious Error has occurred
crapai
crapai
I'm getting a serious error has occured when trying to open a document. Below is a part of the journal file that has error in it but I can't figure out whats going on. We just started getting this with one model.
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application Export To Revit (df5b7489-f0e6-4f83-8010-3d852316d225). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { Autodesk.Revit.Exceptions.ArgumentException exception(The requested dockable pane has not been created yet.
'Parameter name: id) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application DynoApp (a7cc11aa-02eb-4a3a-9847-fc0183916b1d). Changes made by this handler are going to be discarded. }
'E 26-Feb-2019 16:12:38.246; 1:<
' 2:< CoordinationModel FileCache: cache location: C:\Users\cjr\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2019\AddinsData\CoordinationModel\FileCache\zi3lqlxl
'Parameter name: id) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentClosingEventArgsProxy event. The API event handler was registered by application P&ID Modeler (502fe383-2648-4e98-adf8-5e604719dc34). Changes made by this handler are going to be discarded. }
crapai
So far I've had errors opening files in the mechanical and technology department. I'm going to get the tech journal file and compare them.
crapai
I've had some luck with uninstalling and reinstalling the AutoDesk Desktop App. One person expriencing this error also mentioned that they had issues with the Desktop App so they uninstalled and reinstalled it and they were able to get into their project again. It has worked with me aswell, but I'm skeptical until I try it on more computers.
Edit: person number 3 the above process worked.
