How do I combine three parameters (in a shared property set) into one column on a schedule? Each of the manufacturers and catalog numbers are text parameters. In AutoCAD MEP, I was able to use a formula to combine them into one column, but I haven't been able to make that work in Revit.
This is not currently possible in Schedules. The best you could do is enter the values as one Parameter like:
"XXXXX YYYYY ZZZZZ"
The line will be broken and wrap when the excessive amount of spaces are. This is not a good solution, so I recommend using the link below to voice your concerns. This link is frequently provided by Autodesk personnel around here.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
In a project I had to do something similar. One family several types and several possible manufacturers for each type.
I ended up with a schedules like this, which was sufficient for my project.
Above screenshot is a schedule of one family (Troffer Light 1) with two family types (A & B).
However it takes quite some work to get to this.
Basically, within the family I nested three instances of a dummy family (containing the manufacturer/model data)
Maybe this would be sufficient for your project. And it dpeends a lot on how many you would have to do.
Louis
Please mention Revit version, especially when uploading Revit files.
