Schedules not updating on sheets
해당 사항 없음
11,340 조회수
32 답변
1/33 메시지
해당 사항 없음
I have a schedule on a sheet that occasionally will not update.  The schedule itself updates but not the view on the sheet.  I have to remove the schedule from the sheet and put it back in to get it to show the current status of the schedule.  I have seen this on old threads but nothing in 2019.  Has anyone had this issue and might know the fix?  Thanks
수락된 솔루션(1)
11,341 조회수
32 답변
답변 (32)
2/33 메시지
수락된 솔루션
I have had it happened randomly in 2016. Not sure about other versions. Fix can be one of: cut and paste in place, remove/replace, restart revit.
3/33 메시지
해당 사항 없음
DELETE the schedule placed on the sheet, then UNDO (Ctrl+Z).
* Double check that your schedule is not pinned which may affect how it properly refreshes or updates.
4/33 메시지
RougerieTangram23
I have the same problem on revit 2019.2 - gross area schedule not updating on sheets !!!
5/33 메시지
ElrinaMills
@joan_allen
I am not finding anything on the Knowledge Network about this and it seems to still be an issue.
Do you perhaps have more information?
If this answer provides a solution, please mark this post as the solution.
Elrina Mills
6/33 메시지
AlexWythe1233
Issue still exists in 2019 at least and I note it has been an issue since at least 2009.
Seriously, schedules are CRITICAL, an error in an accommodation schedule could result in hundreds of thousands of dollars worth of loss and Autodesk STILL HASN'T FIXED SUCH BASIC FUNCTIONALITY AFTER 10 YEARS?
7/33 메시지
pwoodM9SJL
Another course of action, quicker than Copy/Paste is to select the Panel Schedule on the sheet, and use the up or down arrow keys to move the schedule a few clicks to get the schedule to update, and put the schedule back to it's original position by reverse order of arrow  key clicks. Hope this helps.
8/33 메시지
pwoodM9SJL
9/33 메시지
AlexWythe1233
Still a problem in 2021. Autodesk, please fix this.
10/33 메시지
RobDraw
Autodesk provides a product feedback page for your thoughts.
Rob
11/33 메시지
lisa.kroon
still having the same issue in Revit 2023.. luckily I was able to spot the difference before sending the info out.
12/33 메시지
Finn1337
Having the same issue in REvit 2023.1!! How is this even possible?! Should really be a priority fix!!
13/33 메시지
HVAC-Novice
This is a bug I've experienced over 10 versions. Schedule will update when you re-open the project, or if you wiggle the schedule on the sheet, or sometimes if you open the schedule editor.
Often it works fine (Revise instantly), sometimes it doesn't. I gave up on Autodesk fixing it...
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
14/33 메시지
twellins
Far out... we just issued a schedule and found out the hard way that it did not update.  This is a MAJOR.  Needs priority fixing!
15/33 메시지
twellins
At the very least the printing function needs to refresh.
16/33 메시지
rauza001
If you change one of the sort parameters in the schedule properties Sorting/Grouping from Ascending to Descending or vice versa, the schedule will be forced to be updated. I hope this helps.
17/33 메시지
Finn1337
But that's not a functional solution! I can't go through all my schedules, on all my sheets, to be sure they are updated. Feels silly to be forced to restart Revit before a print och PDF-export. It really interupts the workflow. Autodesk must step in and fix this! After all, it's not a cheap and newely released software we are trying out and beta testing on behalf of a startup company! JUST FIX IT! Without workarounds!
18/33 메시지
rauza001
I agree.
19/33 메시지
Attila.Kalina
None of this is solution, just workarounds.
Solution is to fix issues that have been unearthed for years.
20/33 메시지
RobRocks
Try Product Feedback.
But they do work, therefore they are solutions.
