Schedule not formatting correctly when exported to PDF.
ewolkenstein324
Message 1 of 11
ewolkenstein324
The schedules I created look fine on screen, but when I export them to PDF, the text spills over the column boundaries.
Replies (10)
Message 2 of 11
iainsavage
Its probably a font replacement problem.
Make sure your font is embedded when exporting/printing.
Message 3 of 11
HVAC-Novice
Happens sometimes. I always use the "export to PDF" function. I don't know if using Bluebeam or similar is better. Try some methods and see if it helps.
I don't have a solution, but no, you are not crazy.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 4 of 11
sragan
Are you placing them on a sheet, and exporting the sheet?
Or are you trying to export the schedules directly?
Message 5 of 11
ewolkenstein324
This is happening using export to PDF
Message 6 of 11
ewolkenstein324
They're on a sheet that I'm exporting
Message 7 of 11
ewolkenstein324
Can you explain how to make sure the font is embedded? I'm not sure what that means.
Message 8 of 11
iainsavage
Most PDF printers that I've used have an option in the settings to embed or capture fonts so that the PDF is a faithful reproduction of what is in the original document.
Here's an example (this is the PDF printer which DiRoots Prosheets uses):-
If you don't have that setting then one of the fonts on your PC will be substituted in place of the document font and might not be an exact match.
I don't know if the Revit built in exporter has such a setting, I've never used it.
Message 9 of 11
luisPDAN6
Have a look at this plugin in the Autodesk App Store that exports schedules to PDF. I never had issues with it.
https://apps.autodesk.com/RVT/en/Detail/Index?id=5541053866952145142&appLang=en&os=Win64
Message 10 of 11
b_bataller5QK77
So this issue requires plugin. And Revit itself is not properly exporting schedules.
Message 11 of 11
iainsavage
As I said before its probably a font substitution problem.
I think maybe the built-in exporter uses Microsoft Print to PDF as the virtual printer(?) and that doesn't seem to have a setting to embed fonts from the original document into the PDF.
If you use the Arial font which Revit uses just about universally the schedules appear, to me, to print faithfully.
What font are you using?
