Same keynote number for different keynote schedule in different sheet
Harywijaya.2
Harywijaya.2
hy Everyone,
I am revit user for several months and now learning about Keynote
Very good feature, quickly for tag but i have a problem
How i put same keynote number but different keynote schedule on different sheet (floor plan)
I've tried but still failed, change in keynote setting, change 'txt file, etc
please help me to fixed up
example like above, same number in different sheet and must different keynote schedule
Thank you
dmiller_SCE
You have two ways that you can control numbering of a Key Note Legend.  You control the method within the The Key Note Settings.
Numbering Method By keynote
Determines the keynote value by the value stored in the keynote parameter or selected from the keynote table. This value displays in the keynote as well as filling in the keynote parameter.
By sheet
Numbers keynotes according to their order of creation.
A value for the keynote parameter is still stored if one has been chosen.
A Keynote Legend displays the Keynote Number according to the order it was created instead. No number appears in the tag until the view bearing Keynote Tags is placed on a sheet view.
Additional Information:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
