Does anyone know how to add the symbols I mentioned in the header? It was simple in ACAD, percent percent something, I can't remember... been REVITIZED I guess.
Solved by CoreyDaun. Go to Solution.
Inserting symbols into Revit is a pain - you have to copy/paste or use the Keystroke, which can be found under your Character Map.
text in input in
Symbol AutoCAD Revit
° %%D ALT+0176
Ø %%C ALT+0216
I've also found that you can override dimension text (shhhhh, it's for details) by copying and pasting the ' and " symbols from the character map.
That's great (for details). Just don't let anyone from the Architecture forum know...
I've used these symbols to do that in the past:
ʼ ˮ
Remember that when you use the ALT codes you have to use the number pad. The numbers on top of the letter key's won't work.
