Rise drop symbols disappear and appear randomly in Revit
Is there a fix for rise/drop symbols randomly disappearing? Workarounds are not acceptable.
Current incident ID: 139689
Projects are being submitted with information missing from the drawings and this not acceptable.
Replies (19)
RobDraw
How can random be fixed? The problem needs to be repeatable in order to find the cause.
Rob
So it's acceptable that a product (paid) is not capable of completely performing all it's functionality?
dmiller_SCE
I have also experience the randomness of the riser symbols disappearing. The only fix that I have found to work is to select the pipe and move it vertically and then move back to pervious height and the symbol reappears. The symbol appears even thought the pipe is at the same elevation as previously.
RobDraw
I think that's a completely different topic.
Rob
I've also noticed if I change the associated level, the riser symbol will come back, but trying to do this for every level on a high rise could time consuming, and they might disappear again........
While replying, I fixed one riser, synced, closed and reopened, and the rise symbol is gone again.
RobDraw
Have you tested if they print when not shown?
Rob
Yes, that has been test, the missing risers do not show when plotted.
RobDraw
Do they just as randomly come back if left alone?
Rob
Based on my experience with the issue, I have never seen them randomly come back if left alone.
kadmonkee
pipe symbols relate to the cut plane in some cases if the Pipe Rise or Drop does not cut through the space completely it might be stopped below the cut plane and cause the disappearing symbol issue.
confirm your Segments and Sizes are associated to all the scales you are using and your Pipe Fitting and Rise Drop symbol size is set.
are you using any phasing for the design? phase created in will cause this behavior too.
without adjusting your Pipe Rise /Drop in the model try changing your display visual style from fine to course and back to see if that impacts things as well
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Unfortunately I have already tried all those suggestions.
I also tried changing the annotation scale size in MEP setting and then changing it back, but nothing seems to help.
dmiller_SCE
I believe that I am experiencing the same problem. I have manipulated all settings possible to get consistent results but I still get them randomly disappearing. Here is an example shown in the screen cast. Notice that all of the pipe are the same size, elevation. Also all are from the same reference level. Some of the risers do not display. Only fix I have that works is to move the horizontal pipe down and then back to the original elevation.  The pipe or riser is not sloped, and no plan regions. What is ironic is that the risers right next to it shows.
That is the exact problem we are having. When you sync, close and reopen, dose the rise symbol disappear again or does it remain?
dmiller_SCE
Almost always goes away if I close out and open back up. The pipe will still be at the same elevation and no other users would modify the elements.
RobDraw
What happens when the view is duplicated with and without detailing?
Rob
Good question, I'm reopening the project now to test that out.
I just recently had an issue in 2018 on another project where the view was just not correct, it was showing another level completely. I duplicated the view (with detailing) and everything was fine.
EDIT: Duplicating the view didn't do anything.......
dmiller_SCE
On the views that I have problems with, I get the same results with duplicating with or without detailing. IF I close the file and open it back up the risers will disappear despite me fixing them and they clearly show before I close out.
vincent_cadoret
One of our clients is still experiencing this very same issue (Revit 2019.2):
The parts circled in red should show pipe rise symbols.
In their case it can be quickly fixed by pinning and then unpinning all pipe fittings in the project.
However, the issue returns after only 2-3 syncs with central.
It does not seem to be resolved in 2020.
Any update on resolving this issue Autodesk?
msanschagrin
I know it doesn't solve the issue, but at least Adesk's aware of it and working on a resolution, according to:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Maxime Sanschagrin
BIM Director
Pageau Morel
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
