Revit vs Autocad MEP
Message 1 of 29
Good day,
Currently I'm looking at two software which is Revit and Autocad MEP for learning. But I was wondering, which one  is better for use in current market today. I am working more towards on HVAC systems. I understand that both provide the platform to do HVAC system works. The question in my mind is which software is better, is it Revit or AutoCAD MEP? and do Autocad MEP provide the platform for analysis and in Revit aside from clash detection analysis is it offer any other analysis?
Please clarify this, Your insight or reply is appreciated.
Replies (28)
Message 2 of 29
RobDraw
Since you are asking in a Revit forum, the answers will obviously be in favor of Revit.
Rob
Message 3 of 29
ya.because i have no idea where to post this kind of question. But is it possible to know in what way does revit offers more compare to autocad mep
Message 4 of 29
when in doubt, I search with google - best hits using 'Autocad MEP vs Revit MEP'
https://www.indiacadworks.com/blog/autocad-mep-vs-revit-mep-which-one-is-better/
https://www.augi.com/articles/detail/when-bim-is-bim-comparing-autocad-bim-and-revit-bim
In my case, one of clients insisted on using Revit.
As for the market, based on my experience it will depend on your clients.
As for which to learn? Why not both? I'm old (58), and glad I'm fluent with many different software, makes learning yet another one (Revit) that more simpler.
Best
Henry
Message 5 of 29
Scott_D_
The coordination capabilities and multi-disciplinary model sharing features of Revit are worth the price of admission alone, anything else is just icing on the cake.
AutoCAD Electrical certainly has its place but you cant use it for BIM in anything like the sam way as Revit. With that being said Revit is not a calculation tool in any way, shape or form, at least at the moment.
Message 6 of 29
chris.kershaw
Sorry Scott.dakin but thats not true 'Revit is not a calculation tool in any way, shape' We design pipework & ductwork systems in Revit & with the Elumtools addon you can do lighting calculations too. Ive just tested elumtools & its its very good.
As for the original question dont wast your time learning anything but the very basic CAD commands. there is nothing Autocad can do that revit cant do plus revit dose much much more. We employ trainee BIM people & Apprenticeship BSE students & no longer teach them AutoCAD
Message 7 of 29
Scott_D_
Perhaps I should have put the word 'accurate' in there somewhere with regard to the calculations.
The duct sizing mostly works, the pipe sizing is horribly broken, electrical calculations don't work and single phase panels are completely broken.
Elumtools is not part of the standard Revit software package although I agree it is very good, I wish my company would buy it. It's not for a lack of asking....
Message 8 of 29
chris.kershaw
can say about the electrical not done much with that but the pipework & ductwork work well Ive tested both against other software & manual calcs & revit was closest to the manual calcs
Message 9 of 29
Scott_D_
Might be worth checking out this thread on the front page of this forum - "Pipe Annalysis, Revit PIpe Sizing, flow GPM"
Message 10 of 29
chris.kershaw
Im based in the UK & from our testing Ive not had the problems described on that forum the only time we got incorrect results was on the very low outputs (single sink) giving a 22mm pipe instead of 15mm
We did a lot of testing both stand alone.
Message 11 of 29
Scott_D_
Our building was about 4000m² with mixed offices, general use spaces and bedrooms, all with ensuites.
I have also tried very small samples which also did not work correctly.
Message 12 of 29
HarryHighpants
Agree it's pretty handy for pipe and duct sizing. That being said, HVAC design involves a lot more than just sizing. As it stands, Revit falls well short of being a proper design tool, especially in the area of ventilation which is fundamental to HVAC design.
Message 13 of 29
RobDraw
Falls short how?
Rob
Message 14 of 29
HarryHighpants
@RobDraw wrote:
Falls short how?
Fresh air calculations - especially in VAV systems. Not to mention there is no provision for make-up or transfer air.
Unless you can enlighten me..
Message 15 of 29
s.borello
It's like comparing apples to hand grenades... very different software.  Will you be doing BIM? if so I would use Revit.  I would also recommend you familiarize yourself with both Revit and AutoCAD MEP.
Message 16 of 29
Scott_D_
I just tried AutoCAD MEP as I haven't used it before.
There doesn't appear to be a big obvious 'create electrical circuit' button like there is with Revit.
Seems overly complicated and old-fashioned to me but then I am used to Revit.
I did quite like the wire trimming options however, Revit needs a dose of that.
Message 17 of 29
RobDraw
@RobDraw wrote:
Falls short how?
You're being very general without any substance.
Fresh air calcs - Can you please explain what you are referring to?
Provisions for make-up and transfer air, what kind of provisions would you like?
Rob
Message 18 of 29
HarryHighpants
Rob, apologies if I confused you.
I was speaking to those on the engineering side of HVAC. They know what I am referring to.
Again, for general drafting and 3D coordination, Revit is fine.
As a HVAC engineer, I can tell you that 50% of the engineering design is done outside of Revit because the capabilities just aren't there. I know there are useful add-ons for Revit (eg MagiCAD), but that's a different conversation altogether.
Message 19 of 29
RobDraw
I'm on the side that you speak of. That is why I asked for some context.
Rob
Message 20 of 29
ben
We switched from Fabrication AutoCAD MEP to Revit a couple/few years ago, and I'm glad we did. Revit makes it so much easier to actually visualize the building and makes it easier to see structural obstacles such as beams.
Here are a couple of side by side comparisons of what you see drawing in Revit vs drawing in CAD. Technically they were both drawn in Revit, but on the first one architect and engineers used Revit so you can actually see the walls, beams, trusses, everything. The second one everyone else drew in AutoCAD and I put the CAD file in Revit; you can see it's just flat, no depth, nothing.
RevitRevitAutoCADAutoCAD
You can see from the side views that the CAD drawing is flat (the pink line is the entire level from floor to ceiling). My piping that I drew with Revit has actual depth and elevation, but the building drawn in AutoCAD has none. The Revit model has an actual building that you can really see.
AutoCADAutoCADRevitRevit
Also, AutoCAD uses "layers" and Revit uses "visibility graphics". In my opinion, Visibility Graphics are much easier to understand. Using walls as an example, it's the difference of one thing that says "walls" and next to it you get the options of how do you want to see it, a percentage of transparency, color, etc. Whereas in CAD you have to  try and figure out if walls are layer A-WALL, A-WALL-IDEN, A-WALL-PATT, or sometimes one of 12 or so different things listed under an "A" layer category. There's no consistency with the AutoCAD layers, one architect might have 12 different A-WALL layers for different things about the walls (and different types of walls), and they all label them differently. However, in Revit it's it's always consist and they fall under "walls". Just like instead of a million different layers for duct work there are just visibility graphics categories for duct, duct fittings, duct accessories, air terminals, etc.
I'm glad we switched from AutoCAD to Revit.
Revit lives in the land of perfect and doesn't understand what construction is.
