Revit Task Automation For MEP Model Preparation & Export
henry_eduvie4GZRT
henry_eduvie4GZRT
I am currently using version 2022 and I need to issue MEP models on a bi-weekely basis to my client. I must implement the following tasks before every issue:
  • Delete all views except the default splash/home view
  • Delete all sheets except the splash sheet
  • Purge all unused families
  • Compact the project file if possible
  • Export the model to IFC 4 format
  • Export the model to Navisworks NWC format
Can anyone suggest how i can automate these tasks
I look forward to hearing from you all
Thanks, in anticpation
Regards
fabiosato
You can use e-Transmit to delete views, sheets and make the purge, I suggest you to leave a 3D view to Export to Navisworks and IFC
Fábio Sato
mari.shimode
Hi @henry_eduvie4GZRT, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
