Hello everyone,
I hope you are doing well.
I'm wondering if anyone can help regarding the Revit Systems Analysis toolkit. I appear to get inaccurate peak outside temperature conditions at Time of Peak. Namely, a 0.0 C Dry Bulb and a corresponding Wet Bulb of 32.9 C, the design psychrometry for this space, particularly the outdoor air relative humidity is also not realistic, I would expect somewhere in the region of 60-70% not 28.5%, it is Cape Town not the Sahara desert. I have seen multiple posts on this forum related to other issues around Systems Analysis where I notice their temperature values report more realistically and I would like to get assistance with my issue, which I believe is the last piece of the puzzle that stops me from progressing further with the Systems Analysis tool.
I am trying to perform a basic analysis on a simple room with a single space to test this issue.
I have done the following steps on Revit 2024.2:
- Created an arbitrary room 5.7 x 4 x 3.1 m in size consisting of a 300 mm generic floor set to level 0, 200 mm generic wall with its base at level 0 and top at level 1 with no offsets and a simple flat roof the same size as the floor. Default construction sets were used. There are no overhangs present.
- Assigned a space within this room with extents at level 0 and up to level 1, occupiable and condition type set to heated and cooled. No other settings were adjusted.
- Two water loops, one chilled water and the other hot water were created and assigned to a Four Pipe Fan Coil zone equipment unit and set to one per space. A system zone line was drawn across this space and assigned to the zone equipment.
- Location was set to Cape Town, South Africa (WMO# 688160), all other energy settings were kept as default, this includes default building types, space types and resolutions.
- Analytical Surfaces schedule was consulted and no air surface types were found, indicating an airtight model.
- HVAC Systems Loads and Sizing workflow was selected and run.
I have attached my eplusout.err file to this post in hopes that I am missing something obvious but I suspect the problem lies either with my copy of Revit (how else would it explain other users getting reasonable outside design temperatures?) or a connection issue to the weather data servers.
I will assist in any way to get to the bottom of this issue.
Kind Regards,
Tazden
