Revit schedule IF statement
Jrooker06
Message 1 of 9
Jrooker06
I want to create a If statement that will return a value between two things.
I have 3 columns that we will call column A, column B, and column C
column 'B' will always have a default text in it like lighting and column 'C' will be blank.  I want column 'A' to always bring in Column 'B' until I place something in column 'C' then i want Column 'A' to bring in 'C'
what will this formula look like?
Replies (8)
Message 2 of 9
L.Maas
Same like in families. This is unfortunately not possible you can do something for types like numbers and lengths. But IF statements does not work on the text type.
Example 1
A = "Apple", B= "Banana" A, B, C of type text, C is the calculated value
C: IF(A="Apple", "Apple", "No Apple")
Will generate an error
Example 2
A = 1, B= 2  A, B, are integers  and C is of type text, C is the calculated value
C: IF(A=1, "Apple", "No Apple")
Will work
So comparing text will not work.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 9
Jrooker06
Using example 2 is there a way to make A=''''(nothing) so if Cell A is blank it will return a value? or does it have to be a  calculated value still?
Example 2
Message 4 of 9
jdiala
Not possible, since you can't test if the parameter value is a text. See family attached and go to family types.
Message 5 of 9
Jrooker06
So if I am reading this correctly, you are controlling the statement with a yes/no parameter. By having the box checked then it will pull in your text.
Message 6 of 9
jdiala
Yes, that's the only way to do it.
Message 7 of 9
Jrooker06
would the formula be the same say if the false statement was pulling in the space name. [   =if(C,Space Name,b)   ]
Message 8 of 9
jdiala
I know where you are going. Revit formula is different with lisp. So far you can't test an expression if your test value is a text. You can only test if it's a numeric value or yes/no.
Message 9 of 9
Jrooker06
Okay,
But do you think if i tie a yes/no to a space name in the schedule that it would pull in the space name?
