Filling in a Panel Schedule
NickD22
NickD22
I have some lights in my project that I need to circuit and place in a panel schedule.  When I select the lights to circuit and press the power button, none of my panels show in the drop down.  The specific panel I'm trying to ciruit the lights to has 4 open spots but for some reason it won't let me select it or any panel.
Thank you,
Nick
russellvee
Your light fixture power connector is probably set at 0 volts. I run into this a lot with families from manufacturers. You have to go in and set it as a balanced one pole connector at 120 volts, or whatever your panel L-N voltage is. Otherwise it won't give you the option of connecting it to the panel.
NickD22
You are absolutley correct.  Thank you.
