REVIT Pipework - Family Fitting 'PART TYPE' bugs and errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
To follow on from my previous post, several more problems/ BUGS? I have stumbled upon creating customised pipework fittings. I have noticed several issue with fitting family PART TYPES.
To try explain in my illustration I have used the same model geometry but just changed its PART TYPE in the family.
Certain types display incorrectly the geometry appears flawed, some types instanced parameters cannot be edited.
I have tried to break it down to illustrate the flaws/problems with certain PART TYPES some work as expected some display incorrectly some are not editable some cannot be even aligned?
Also note the display errors even vary with the Discipline and have very odd behaviour I cannot pin down.
I have attached the template file should you want to drill deeper into the problem and see it close at hand.
The fitting I have modelled in this example is a fully parametric Ductile Iron Bellmouth (with gasket visibility parameter) but note this behaviour can be found using any shaped geometry it just was a nice shape to use.
Please note this is far more than a Graphics card problem (see PDF) so no 'reinstall you display drivers' please.
The more I think I know about REVIT the more problems I'm finding, this is really frustrating and basic stuff that should have already been addressed a long time ago..
Many Thanks for looking in and your feedback is greatly appreciated but I feel this is another case I need to raise with AutoDesk dev team.
Cheers
Glenn
