Message 1 of 8
Some elements don't look as though they are connected properly and some of the ducts look as though they are not orthogonal.
Check this first, make sure everything is connected and straight.
Your centrelines do look particularly wavy though.
it looks like they are not connected properly. thanks
Is your project located kind of far away from the internal origin? The irregular triangles and the axes look that way. Although there is some 33 km limit to everything, there is a limit to the move command at a bit more than 9 km. It is likely that there is a reason for that.
It almost looks like sketchy lines has been turned on? if so try turn it off. But I also agree with the responses above.
No, sketchy lines is turned off.
It is possible that your file or some linked file has some component very far away from the project origin.
This issue may cause these graphics problems.
Fábio Sato
Thank you , i think that is the problem!👍
