I am having trouble determining how to map the Revit MEP sytems to CAD MEP Services. When I type "processrun" in and atttempt to load the RIF. nothing occurs.
Can anyone help with this?
Please and Thank you,
Ashton
ashton-
When you bring a riff into a Fabrication file it brings it in as design lines. Double click the design line and fill with the service you want to be filled with. Take a peek at the design line help file https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
You need to follow the Autodesk process for this, there is quite a bit more to it than just importing the file, it needs to be told what to translate the design line into.
