That is confusing. The out of the box recepts do have a connection, the snap symbol looks like the node in AutoCAD. You should still be able to circuit it even if you cant find the node to draw a wire from....provided the connector is there. Try selecting the recept, then see if the grip shows up. If not, then try a different recept, or edit the family and add your own.
