Revit mep filter
Revit mep filter
Revit mep filter
I'm new with Revit and i've a problem with set a filter to pipe system. I try but its not working properly.
I'm trying to set a solid color to pipe system.
Can anyone help me with this :?
Thanks a lot.
Mira
www.TechRoom.bg
Hello Mira,
Dont worry it's not so hard to set a filter to any elements ( pipes too ).
Ok when you create your pipe system go to Project browser menu -> Families -> Pipeing systems -> Select your system -> Right click -> Type properties -> Now you will see all editable parameters for systems in revit -> Click to Graphics overrides -> EDIT -> Select new color and switch patern to solid.
Here is official autodesk help for filters: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Thank you !!
Its work perfect.
