Announcements
Revit Mep 2015 Template Files are Missing
hossamnet0semo
hossamnet0semo
Template Files of Revit Mep 2015 are Missing !!!
What Should I Do ???
Replies (9)
kadmonkee
go into Revit options
select the file locations name
select the green plus symbol
browse to where you keep all your templates.
add as many templates as you like
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Matt__W
@hossamnet0semo, quick question... did you ever have the correct paths? The Screecast below will show you where to find the paths.
Depending on where you've installed Revit, the paths may be slightly different.
FILE LOCATIONS
Construction Template : C:\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Construction-Default.rte
Architectural Template : C:\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\default.rte
Structural Template : C:\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Structural Analysis-Default.rte
Mechanical Template : C:\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Mechanical-Default.rte
Default Path for User Files : C:\Users\\Documents
Program Path for Family Template Files : C:\ProgramData\Autodesk\RVT 2015\Family Templates\English_I
Root Path for Point Clouds : C:\Users\\Documents\PointClouds
PLACES
Imperial Library : C:\ProgramData\Autodesk\RVT 2015\Libraries\US Imperial\
Imperial Detail Library : C:\ProgramData\Autodesk\RVT 2015\Libraries\US Imperial\Detail Items
Or you could also try resetting the Revit.ini file.
1. Close Revit
2. Find and delete or rename C:\Users\<User Name>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2015\Revit.ini
3. Restart Revit
The INI file will automatically be copied back to that location from the Cache folder and should have the default paths.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
hossamnet0semo
Eng @Matt__W i followed your Replay but I did not Find the Template Files inside The Template Folder for my revit mep 2015 non metric or imperial nor families
where can i get them ? or download them ?? liaberary? @ Templates?? @ Famelies??
hossamnet0semo
Eng kadmonkee i cannot Find the Template Files inside The Template Folder for my revit mep 2015 non metric or imperial nor families i do not have Them !!
Matt__W
If you go to Windows Explorer, can you see the ProgramData folder? By default it's a hidden folder. You may need to turn it on. I just want to verify that you do in fact NOT have any templates/families installed.
Matt Wunch
Twitter | LinkedIn
Matt__W
Another quick question... is this a new installation of Revit 2015?
Matt Wunch
Twitter | LinkedIn
hossamnet0semo
*Ans of 1st Question :-
>>Yes, I Know it is Hidden By Default And I Made Unhidden to ProgramData
But Still Template @ Family @ Liberary Files Are Missing as Shown in Screenshot .
*Ans Of 2nd Question:-
>> Yes, it is new installation of Revit MEP 2015
What Should i Do?!
stever66
Matt__W
@hossamnet0semo I would uninstall and reinstall using the Virtual Agent direct download to download the entire installation package. Follow the steps below to perform a clean uninstall & reinstall.
STEP 1
Please refer to this AKN article for information on how to perform a clean uninstall
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
STEP 2
Make sure you have the websites listed in this Autodesk Knowledge Network unblocked
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
STEP 3
Remove as much as possible from your %TEMP% folder
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-delete-temporary-...
STEP 4
Then download the entire installation package for Revit 2015
http://efulfillment.autodesk.com/SWDLDNET4/2015/RVT/DLM/Autodesk_Revit_2015_English_Win_64bit_R2_dlm...
STEP 5
Once it's downloaded, simply run (double-click) the executable file. Follow the prompts to install Revit and the desired content.
STEP 6
After successfully installing Revit 2015, make sure you download the latest updates, too. You can find any available updates at your Autodesk Account Management page. The most recent update for Revit 2015 is the Release 2 Update Release 14 (R2UR14), build # 20160512_0715
https://knowledge.autodesk.com/support/revit-products/downloads?release=2015
Matt Wunch
Twitter | LinkedIn
