- Mute
- Permalink
- Report
Does anyone know what is the length of a space, dash, or a dot pattern in revit? I've seen where you place in a value after the type, but I don't know what the "1/2" or "1/4" values mean. Is that saying that the dash for the particular pattern would be equal to .5" or .25"?
Also, what would be the best value to add for a line pattern if I did not want to go any lower than 1/8"=1'-0" scale? The issue I'm running into is I have added a pattern to my pipe systems in revit and they are hard to see as I increase my scale from 1/8"=1'-0" to 1/4"=1'-0" I'm looking for a general line pattern standard for a double dash, center, and double dot line that will still distinguish my cold water pipe from my hot water pipe as my scale is increased from 1/8"=1'-0" to 1/4"=1'-0".
