Revit How to sync open files
kyeongmo_anPB933
Observer Observer
kyeongmo_anPB933
Observer
Observer
hi.
Revit How to sync the entire open files at once Is there none?
method or add-in
thank you.
craigjonnson
You can only syncronise one file at a time.
Mahmoud.Ziedan
If you mean to synchronise more than one Model,that are different...
simply open each one of the models on a different Revit.
so when you have 2 instances of Revit opened with 2 different models then you can synchronise them on the same time without interfer
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
