Revit-filters, patterns not working
m.miki98
m.miki98
Hello. I have a problem with the filter pattern option. I did it before  in another project, and worked well. But now I'm trying to change for example the color for the pipe accessories, and it's not changing. The filters are correct, because I can change the lines or the transparency, only the pattern not working.Screenshot 2022-01-12 125513.pngScreenshot 2022-01-12 125136.png
m.miki98
Uptade: Meanwhile I solved the problem, the Graphic Display Option was on realistic. Changed to shaded and now all colors can be seen.
