I have created a simple L shaped extrusion but when I go to align the two ends with the object it is supposed to sit on the end that gets aligned moves the whole object and keeps its length instead of "stretching to that new length". The length of the extrusion is tied to 2 reference planes and is dimensioned by a instance parameter. You can however stretch the two end by pulling the nodes. it would be much faster to use the align tool..... Thanks
Solved by craigjonnson. Go to Solution.
Its made to stick to the top of a cable try and show the above and side clearance. The length is the only problem. Thanks again!
It works inside of the family but when it is actually placed in a model the object sticks to one size. When aligning one edge to something the other end moves with it.
before aligning
after aligning
I would like the model to "stretch" to the left end instead of simply moving
Thats exactly what I want to happen and when I follow the exact steps you are even in a new project I am getting the result above. I really appreciate all the help!
Pleased to hear that you had this resolved. Would you mind accepting Toan's response as completed, it helps the forum members know that a particular question has been answered.
Thank you.
