REVIT Fabrication
02:12 AM
- Mute
- Permalink
- Report
I am using Revit fabrication to try and produce fabrication spool drawings, I seem to be having a problem on, say for example the welded and socketed spec, when adding in a break flange ( a lot of our sites there is no welding on site) so we weld up in 6m x 2m x 2m spools and bolt them on site,
I am finding that Revit doesn't add in the flanges where I require them and will not split the pipe where I require, for example if I need it split at 5m as there is a wall in the way.just seem to find it clumsy
