Revit Fabrication Reports File Location for Reports
How is this set? Is there any way to set this for all users? We have reports on our network that we want everyone to have access to. Right now it's looking in different locations. I can't find any way to set the locations in the documentation for the add-in.
Thanks.
CraigFarsh
Hi @Anonymous
Welcome to the forum, and apologies that you are having difficulties finding helpful information on this subject.
It is possible to share the fabrication reports. This is done by modifying the configurations map.ini (located in the configurations root folder) file to point the program to a different report location (see highlighted row on the image below).
Revit uses the CADmep report location e.g. (C:\Users\Public\Documents\Autodesk\Fabrication 2020\my_configuration\MIS\CADmep) so move the files from this directory to the network shared location.
NB. Altering the path in the map.ini affects all fabrication products, so it will be necessary to move all reports to the new location.
Craig Farish
Quality Analyst | Product Owner | Experience Designer
Thanks!
