Revit MEP Forum
Revit Fabrication Grayed out (unable to reload services)
4 REPLIES 4
mbalcarcel
2216 Views, 4 Replies
i made new Second GUID in a autocad for revit fabrication and now i cant reload services.
i accidentally did this when i first learned about making a GUID.
does anyone know how to fix this problem?
im unable to reload configuration right now.
its all grayed out.
4 REPLIES 4
nathan.chapman
in reply to: mbalcarcel
One way to do it which could impact other jobs is to use a tool like Revit lookup to snoop what GUID was used in the Revit model.  Then go to the database and type in that GUID.  This will then allow you to reload the configuration.  Here is the link to Revit Lookup: https://github.com/jeremytammik/RevitLookup.  Let me know if you need help navigating through the tool to find the GUID.  Hope this helps.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Jacob_United
If you have no Fabrication Parts in your model you can use the Purge tool to remove the service and reload the correct one. This worked for me when our IT contractor upgraded our server causing the GUID to disappear on a regular basis.
Also, if you have save points on your system you can restore the database to a time before you wiped the GUID, make a copy of it and open it up to find the GUID before simply pasting it in the current database.
If either of those options are no good to you then I hope you didn't actually need to add or modify any services in that project.
Good luck.
If my post answers your question, please click... Just kidding!
Ghernandez
We have encountered the same thing with other clients. The Fabrication Configuration (Not Available)
I referred to my Go To Fabguru David Ronson. He blogged about this GUID getting changed for some reason and needs to be recovered and changed back inorder to recover the Fabricaiton configuration in Revit. Check out his video on the script and fix.
Search Youtube for the title below:
Recover Fabrication GUID with Dynamo
amargheriti
Did you happen to find a solution to this issue?
I am having the same issue and cannot seem to solve it.
