Revit Electrical: Edit Circuit Highlight Issue for Existing Elements
jbissellG964F
jbissellG964F
Community Visitor
Community Visitor
I'm trying to circuit existing and new receptacles. When I go into "edit circuit," only the receptacles in the circuit should be highlighted black, and the rest of the model should be halftone. However, when I circuit existing receptacles, which are halftone from the start, with new receptacles, the existing will stay halftone when I go to edit the circuit; it's very hard to see if the existing receptacles are part of the circuit. Is there any way to make the existing receptacles highlight black when in "edit circuit" mode?
Normal:
Editing the circuit:
HVAC-Novice
Let me start by saying, I hate dark mode and only tried it for a hot second. Besides personal preference, i dislike it doesn't show me how it will look on actual planset that gets issued. And the screenshots i see with dark-mode, just reenforces my hate.   🙂
Maybe try to set it to normal mode (like it will look on actual plan sheet)?
if you don't want to do that, play with phasing settings:
Another alternative is, make all elements of that discipline red or some other color. That way it stands out from the black/gray of the other elements? i don't know how it looks in dark mode. But i like it for normal mode (and actual construction documents). Below an electrical plan with all electrical elements in red. I don't have existing elements, but I suspect they still show in red (just a bit less pronounced)
YMMV. You have to trial & error a bit to find a way that works for YOU. But IMHO, darkmode make sit harder.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
mari.shimode
Hi @jbissellG964F, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
