- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a build in tolerance in Revit that controls when to show or not show duct riser/drop symbol? (It seems to be <=0.1 degrees)
If a duct is ever so slightly off 90, Revit won't show the symbol on section views. In my case, it's only 0.5 degree off. This makes working in oddly angled area very difficult and time consuming.
To make things worse, you can't measure angle between an element and the section in a plan view, you can't align a section to elements.
So you have to work around to find out if your element is exactly 90 to the section. Then manually move the end point to an element point, then rotate the section/element about that point to make them 90 degrees. Since "move" and "rotate" command can snap to section view line in plan view, BUT not "measure angle" and "align" tools.. Why, why?
