Revit 2024 - pipe / ducts tags with spot elevation properties problem
I do not found similar case, so I will start a new topic.
I encounter a problem with spot elevation properties labels in duct and pipe tags. In tags where a spot elevation are used, a leader don't grab border of tag but go somwhere into the center of the label. It looks like the problem is with an incorrect border calculation for spot elevation properies. For others lower/upper end elevation properties it looks ok.
I create a test project and two simple tags from the default template to eliminate a problem with posibility of corruped files. You can find files below.
I would appreciate your feedback if you got the same result.
