Revit 2023 Demolition Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So the new version has added the ability of demolished MEP elements to maintain their categories in response to multiple request on the ideas forum. Works great except for one major issue. To keep the system type the developers also physically are keeping the demolished element connected even when not visible.
The example I ran into was a project where I need to demolish all ductwork downstream of an existing terminal unit to allow for new ductwork to be installed in a new phase. Downstream ductwork was set to be demoshed in the new construction phase and that worked well. The problem is that when I went to connect the new ductwork to the terminal unit you cannot connect it as the demolished ductwork is still connected in the Revit DB. This is a major issue as we do work on existing facilities all the time and up until now this was not an issue.
