Revit 2021 free student version (serial number issue)
anantmistry1234
Message 1 of 30
anantmistry1234
Hi, there I have downloaded and installed Revit2021 but I don't know about serial number.
So please let me know how can I find serial number and active my software for at least 1 year.
Please let me know about how can I find serial number after installing my revit 2021 software.?
Replies (29)
Message 2 of 30
Message 3 of 30
mauricio_mssf
you can find it at https://manage.autodesk.com/home,  in all products and services.
But you better download Autodesk Desktop App and Autodesk Network License Manager, and put your login, there you can find your serial and key, but usually the filling will go automatically for your software.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 4 of 30
emanaster
I am also having a similar issue. I did not get an email with a serial number, my same serial number for 18/19/20 does not work even though the 2021 download came with a new activation key (which is usually the only thing that changes when a new update comes out), and i cannot find my serial number in my autodesk account. In fact, under products, it doesnt even show up as having a 2021 license, even though I was able to download and install 2021 through the revit page not through my products page. This is quite frustrating as once my 30-day trial is up, I can no longer open or edit any of my classmates' 2021 revit files since they are not backwards compatible with 2020. Someone from Autodesk really needs to get on this, because I have a few classmates who are having the same issue and have been given the runaround by 3 technicians over the phone support line.
Message 5 of 30
lindberg.august
Community Visitor
Community Visitor
Hi!
I seem to have the same issue. I use a student license and downloaded revit about a week ago. Can´t find the serial number on any of the listed locations.
I downloaded AutoCAD and could log in with my autodesk account without problem.
Have you been able to solve the issue somehow?
Message 6 of 30
mohamedtarek757
Message 7 of 30
mohamedtarek757
You Just need to start the program And Sign in With your Educational Email and Password and click on activation with Autodesk Educational Id
Message 8 of 30
lindberg.august
Community Visitor
Community Visitor
Thank you so much! It worked. Almost feel embarrassed because of how easy it was.
This will help me a lot. Thanks again!
Message 9 of 30
i need serial number revit 2021
Message 10 of 30
RobDraw
You need to read message #7 above.
Rob
Message 11 of 30
n01365986
Community Visitor
Community Visitor
Hi I have also been struggling with this exact issue. I have not received an email with a serial number, no prompts with a serial number when downloading and installing.
Message 12 of 30
 1. Serial number
Message 13 of 30
thank you, I was also looking for the serial number  but all I needed to do was sign in with the Autodesk ID
Message 14 of 30
samyfares336
Fares samy
00201550852904
@samyfares336 - this post is being edited to remove PII.
Message 15 of 30
ch.bhaskar268
Observer
Observer
i waNT SERIAL NO REVIT 2021 to activate
Message 16 of 30
ch.bhaskar268
Observer
Observer
pls give me the  seial no
Message 17 of 30
marzanvkas100
Community Visitor
Community Visitor
Autodesk Revit 2021 Serial Number Required Please Provide.
Message 18 of 30
RobDraw
No, it's not.
Rob
Message 19 of 30
hilalkhan443322
Community Visitor
Community Visitor
i need serial nomber revit 2021
Message 20 of 30
fabiosato
You need to create a student account and use your login to authenticate your software.
Fábio Sato
