Hallo Everyone.
i am currently working on a project. My colleague uploaded the P&id drawing from Plant 3D version 2021 to the BIM360.
When i open my Revit version 2020 and go to the P&id modeler option in Revit, i am not able to see the project he uploaded in BIM360. But when i open Revit 2021 and go to the P&id Modeler option in revit, i can see the project in version 2021.
I want to work with Revit version 2020. Can someone please tell me what is the problem? and how can i fix it.
How can i access to the P&id drawing uploaded from Plant 3d 2021 to BIM 360 via my Revit 2020 version.
Thanks in advance.
You need to use the same version.
Unfortunately, Revit is version-specific. While you can open files from previous versions, you cannot open files from later versions in an earlier version of the software. Nor can you save backwards. Once a file has been saved in 2021, you will need to work in Revit 2021 to continue to access it.
