Good day!
I would like to ask regarding Revit 2020.2,
I didnt know how can I access the Eletrical template in Revit 2020.2
Thank you very much
Solved by bongcajucom. Go to Solution.
Solved by jrobrador19. Go to Solution.
Hi there,
You can check your templates folder at C:\ProgramData\Autodesk\RVT 2020\Templates. If it is not there you can try and download the templates here. The first 2 file downloads there contains the Family Templates and Project Templates for both Imperial and Metric.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified Instructor | Revit Architecture Certified Professional | Revit MEP: Mechanical Certified Professional | Revit MEP: Electrical Certified Professional | Inventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
you can refer to this AKN article for more info regarding update and you can download and install from your autodesk acccount. thanks
