Hi Everybody,
I am trying new update 2020.1 and its new Systems Analysis feature.
I dont know how can I specify "zone equipment" for System-Zones.
I have weather location, revit geometry, spaces, space types, construction envelope specified, system for the whole model also.
Thats my result right now: "EnergyPlus simulation did not generate a report for systems analysis."
Does anyone know how to use those new features?
Solved by RobDraw. Go to Solution.
Solved by cwaluga. Go to Solution.
A rough description can be found here: https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-A262F53F-B389-4846-89EF-5855F55476A5
Most of the functionality for defining zone equipment is in the analytical part of the systems browser (use the create buttons in the top right corner), except for the analytical zone sketch tool, which can be found in the calculation tab.
However, I did not yet manage to get anything useful out of it either. It would be really helpful to see an example or a tutorial.
has anyone had any luck getting a report for HVAC systems loads and sizing from the energy simulation tab in revit 2020-1? When I generate the report it takes asholw and seems to be doing something in the background and supposedly creates a report. But the report just has this text - "EnergyPlus simulation did not generate a report for system analysis"
Gotta cover the basics here. Do you have an energy model, yet? There is a fair amount of work and some settings that need to be addressed to get an energy model ready for analysis.
I think I have an energy model.
I can see the blue boxes in the analytical spaces view (see attached).
Have a look at the AKN article.
I have been able to clean up the "shades" in the model but I am still having issues with one area. This project is a performing arts addition to an existing school. The "Commons" area between the old and new is where I am still seeing shades and it doesn;t create any analytical spaces in this area either. I have looked around for walls, roofs, floors, etc for continuity but still nothing.
I also have same problem here. the energy model is OK and have no problem generating in Insight. heating/ cooling load analysis is also OK
But for system analysis it always shows no result
Dear community friends;
Dear friends of the community, finally I found a very simple solution to solve the error "EnergyPlus simulation did not generate a report for systems analysis" and I want to share it with us.
Simply put, it is an update to the OpenStudio that Revit uses to process all Energy Analyses 🤔
👉Watch the following video for more details - https://youtu.be/jUtnFJKwHzE 👀
If you found my comment useful or it was the solution to your problem, give it a Like and Mark it's a Solution!
Best wishes! 😎
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
