Hi @CIPuyleart,
Thank you so much for your feedback.
I understand the challenges you are facing and I really wish that we would not have to bother you with the troubleshooting steps I described in my earlier post.
As you´ve probably seen this in the earlier posts in this thread: What makes this issue particularly painful both for Autodesk´s investigating teams and the affected users is that:
- it appears sporadically only - so we cannot be 100% certain on the steps to reproduce
- it doesn´t seem to be reproducible on all environments/ systems with the steps that affected users assume to trigger the issue
- the investigating team couldn´t reproduce the issue yet on any set-up test environment with any project data
- even just to get a real chance to track down what exactly is happening when the issue occures - doing this based on diagnostic data only - the investigating team needs a very extensive amount of data to be collected - parts of the dataset only are most likely not enough
- It is very important that the diagnostic data gets collected right after the issue happened, otherwise important information might get even harder to track or overwritten and entirely lost.
But again - I understand entirely that your project work has absolute priority and I appologize for all the troubles this issue has caused you.
I suggest to make the entire affected project team aware of the steps to be done, and the questions to be answered, when they see this issue happening again. And make sure that they follow all of the described steps accurately right after the issue has happened.
Here again as a reminder:
I´ve collected a few questions and a list of steps to execute, that our investigating team will need:
- Is the issue consequently reproducible or does it happen sporadically only?
Can you identify any particular task or workflow that seems to precede the issue - if you can, please, make sure to describe the steps very accurately step-by-step (as this seems to be a rather rare behavior, any detail can be important)
- Can you reproduce the same issue on a simplified test file on the same environment? (if you could, that would help a lot with the investigation - a complex model with a lot of elements / assemblies make the investigation a lot more difficult)
- Can you reproduce the issue with one single user being logged in making changes/ synchronizing or do you need other users to be in the model as well for the issue to happen?
- If yes - do those other users have / have no active license of Victualic Tools
Right after the issue is reproduced, please, execute the following steps to gather data for the investigation:
- “Save As” a local copy of the open Revit project file with the changed assemblies and send it together with the collected data (listed below)
- Note the names of the assemblies that have been changed (and note the element ID´s of at least one affected assembly)
- Gather and send us:
a. The username for the user that created the assemblies.
b. The approximate time that the assemblies were created.
c. The last time that the model was synched without the name duplication.
d. The time when the duplication first was seen (and the username of the user that saw this, if different from 1 above).
e. Get a collector utility dataset ( from every user working with the cloud workshared model over the time in question (from 2-4)
f. The locally saved project file (with the renamed assemblies)
g. All files in the local cache folder (C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\ \CollaborationCache) of each users who were working in the model at the time the issue happened
- Make sure to name the folders of the data in a way that the data of the separate users are easily identifiable
- Feel free to send me a download link for sensitive/ confidential data in a private message
Thanks again for your understanding and for your cooperation.
One more question at the end: Is your project team related in any way to the project team/ office/ C4R project/ IT environment...etc. to other users in this thread, such as @henryalgermissen, @ekrout, @Anonymous ?
Best regards,
