Revit 2018 Coordination Model Publish to BIM360 Team
MonicaCJ87SB
MonicaCJ87SB
I am trying to Publish my coordination model from Revit 2018 to a BIM360 Team project. Even though the export seems to be successful, seems like it cannot be viewed on the A360 viewer.
Anyone used this workflow before?
Fixes i tried:
- Only exporting the default {3D} view by changing my publish settings
- Changed the section box around my model to be much smaller so I make sure the extents are not an issue.
Let me know if you have tried and succeeded with a similar workflow. Not sure if that integration is just not supported yet with A360 - Revit - nwd.
From my experience the publish usually works fine, but it doesn't show any links on the front end of BIM360 team.
I just create a NWD and publish that straight to the front end of BIM360 Team. Seems to work, though with big models it takes a long time to load.
MonicaCJ87SB
Thanks! I was able to load the NWD directly to BIM 360 team and seems to render fine although it took a while!
Will have to retry the Revit 2018 to BIM 360 Team workflow again.
