revit 2017 systems calculating
mbeckmanUMHKN
Message 1 of 15
mbeckmanUMHKN
how do I shut off the background process "system volumes calculating" and "duct systems calculating"? I figured out how to shut off the flow calculations but not the volume? it automatically starts, and wont let me save while its running.
Replies (14)
Message 2 of 15
rudi.roux
Hi @mbeckmanUMHKN
Welcome to the community! Smiley Happy
It is possible, I see that you already set your systems to Not Computed, but what you can also do to increase the performance or rather prior to synchronizing with the central model is the following...
Scroll down to your Families in your Project Browser >> Duct Systems >> Right-Click on a System >> Type Properties, then under Calculations, select you between the options which would work for you. (You'll need to do this for each system type.)
This is a "newish" implementation from Autodesk and below are two additional links to help you understand what each of the options will do:
LINK ONE (Scroll down the article a bit).
LINK TWO
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 3 of 15
rudi.roux
Hi @mbeckmanUMHKN
I would just like to follow-up and hear if my post served as a solution for you or if you have any further questions?
Rudi Roux
LinkedIn
Message 4 of 15
deshmukhnavid
To turn of the background process in Revit 2017 go to task manager and end the process "Revitworker.exe"
Message 5 of 15
DMagill
Thank you for this response.
This was the key for our issue.
We have never seen this before. What causes the processing to start?
Message 6 of 15
Thanks a lot, that sorted the problem.
Do you know what kicked it to start?
Message 7 of 15
deshmukhnavid
to Improve the performance Revit works in background for calculations
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
Message 8 of 15
deshmukhnavid
I think this is the key to start back ground process in below image. If you will keep Calculations "All" then it would start background process.System_Calculations.PNG
Message 9 of 15
Yep I got it but I just wonder why is that function just kicked out suddenly preventing us to Synchronize when no Properties at all have been changed for a long time? Can a date be setup for it to run? Its always running?
Its strange as this never happened and took us from surprise.
Thanks for your help guys.
Message 10 of 15
Nice...Good adivice...really works
Message 11 of 15
This is not the permanent solution but.
Please, provide the solution with the error doesn't come again.
Message 12 of 15
RobDraw
Actually, it is the correct solution. Calculations shouldn't just turn back on without anyone changing the setting. It sounds like you may have a different issue. Please start your own thread and thoroughly describe your issue.
Rob
Message 13 of 15
deshmukhnavid
Hi, first of all that's not an error that is the back ground calculation process. Which you have to stop or please suggest other solution if you find any. It will help us all.
Message 14 of 15
A bit late to the party, but in Revit 2019 this process did not show up in Task Manager. Not sure if it got tucked away somewhere else.
Message 15 of 15
KatieGKing
Same for 2020 - still  trying to find a way to force it to stop so we can sync
