So I have been working on Revit 2016 for months and now it suddenly hangs at the splash screen. I have tried reinstalling, updating all my drivers and installed all my updates. Every other version of Revit I have tried has worked (2014,2015,2018) and even the Revit 2016 viewer works but not revit 2016. I have seen several solutions for this problem but none of them I found have worked so far. I am not sure at this point what to do. Below is every solution I have tried:
Ran program as admin
Updated all drivers and versions of autocad/revit on machine
Emptied temp folder
Completely wiped revit and all residual files away
Reset the license
Ended WSCommCntr4.exe every time I tried to open it
Uninstalled every program and changed every setting on the computer changed since it stopped working
I've tried more than this but thats what I can remember. I am currently running windows 7.
This question might be better suited for the installation & licensing forum.
See THIS thread on the Autodesk Knowledge network to see if some of those tips might help.
You also can have a look at your journal files to see if something is mentioned what causes the error.
See THIS link to find the location of your journal files.
Louis
Please mention Revit version, especially when uploading Revit files.
Okay. Ill try it in that forum. I have been through all of the threads mentioned and none of those solutions have worked for me.
Try removing any addins.
Last time I had a major error with Revit which I couldn't explain, it was caused by an addin that somehow got corrupted along the way.
You can find more information on how to remove addins at:
