Revit 2013 - Extracting Plumbing from MEP Revit file
I have a 350 meg file with plumbing, HVAC, and electrical. I need only the plumbing. Is there a way to remove the electrical and HVAC while maintaining the plumbing worksets?
CoreyDaun
Hello, and welcome to the Discussion Groups!
If the elements are reliably placed on the correct Worksets, then the best option is probably to create a new 3D View and turn off the Worksets that you wish to retain (under Visibility/Graphics Overrides > Worksets tab) and then just delete all of the visible elements.
