I had made some Typical Assemblies using Mechanical Equipment, and the Pipes & Pipe Fittings..
1-Now the Mech-Equip-ASLY can generate views as per the First Time they were created, and can be copied without creating a "New name given" warning.. or making multiple copies of the same asly.. it's working fine for me as long as there are no pipe / duct / fitting components..
2-Now the issue for assemblies using either Duct / Pipe / Fittings / Accessories etc, always create a copy of the Asly with a unique name making a huge list in the schedule too.. So thanks to the suggestions given above, I am currently circumnavigating the issue by creating a First Asly with the Name "Sample-XXXX" and all subsequent copies with their proper name "XXXX(1,2,n...)" and they show up in the Schedule as individual items, and i can exclude the "Sample-XXXX" using the "Contains filter".. And i then extract the Views for Fabrication from the "Sample-XXX" Only, and use it as Typical Detail..
I hope that Revit comes up with a smart solution to this..
Another Issue i encountered was that if I rotate any Asly View in the Sheet, the Text, Dimensions all go wonky in accordance to the original orientation.. Hence the above solution to create a sample asly to overcome this problem too..
It's just that I need to either hide them (Element Hide) or keep them in a separate space in the project outside the Crop View Boundary..
Any better solutions are welcome..
