Reload DWG to Revit
Reload DWG to Revit
Message 1 of 8
Reload DWG to Revit
Hi all,
Issue:
Client sent revised DWG,
I already linked Xref in revit.
I updated the Xref DWG and getting error msg in Revit.
Help PLEASE
Sohaib
Replies (7)
Message 2 of 8
ennujozlagam
@Anonymous hello, try to audit and purged your drawings if there are xref drawings inside bind it, clean as much as possible then try to reload again, and if possible share the autocad file so we can check. hope it helps. thanks
Message 3 of 8
Hi again,
I did as you recommended, but the issue still the same issue,
Please see attached original DWG and its Xref.
Thank you in advance.
Sohaib
Message 4 of 8
I think you advice is correct indded , the wrong is in my DWG. Smiley Embarassed
Because I opened brand new DWG and do the whole process, it worked fine. thank you for your time dear.
Sohaib
Message 5 of 8
pawel.romaniuk
Hi @Anonymous
This error message can be ignored - Ok a then will reloaded
Your file  Revit_Xref.dwg contain elements from 170503_Gullhaugvn7_1etgDWG_Rev03.dwg  as Block not external reference is there any background/reason to do so ?
Best practices when linking RVT and DWG files into Revit
Pawel Romaniuk
Message 6 of 8
Actually no reason at all.I didn't knew that.
I did:
  1. Recivied new revision from client
  2. Opened new DWG and used comand Xref,
  3. attached DWG, and saved.
This is correct, right?
Message 7 of 8
ennujozlagam
@Anonymous hello, no. that is not correct, that is not the practice linking autocad drawing into Revit, no need to xref  your drawing into a new drawing you can directly link autocad into revit unless your xref drawing is part file or as whole drawings. thanks
Message 8 of 8
fabiosato
Check if the DWG is in the 2018 format, older Revit versions cannot handle some objects.
Open in AutoCAD and save in 2013 format.
Fábio Sato
